Новая версия программы, убирающей защиту регионального кода на DVD-дисках. Нужно просто вставить DVD, и программа за считанные секунды снимает защиту. Т.е. если ваш региональный код не соответствует диску, то программа поможет справиться с этой напастью. Может дешифровывать защиту на лету, не сохраняя данных на жесткий диск. Используется в связке с плеерами и программами для копирования.
What's new:
<!--QuoteBegin--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>Цитата </td></tr><tr><td id='QUOTE'><!--QuoteEBegin-->- New: Added "Jump to Main Movie" feature. Cool! (This option is off by default)
- New: Software and Hardware Region Code removal are now two separate options
- New: Added several workarounds for wrongly mastered titles
- New: Added warning dialog, if AnyDVD detects an unrecoverable Video DVD mastering error
- New: Pressing ESC will leave the settings dialog
- New: Workaround for problems with incorrectly mastered DVDs like "Jim Knopf und Lucas, der Lokomotivführer", "Urmel aus dem Eis" and "Peter Finzel Test Disc V2"
- New: .bup files can now be at any sector address on the DVD and do not need to follow the video material
This fixes problems with DVDs created with broken mastering software or DVDs created as DVD-ROMs instead of Video DVDs.
- New: All I/O is now moved to a separate thread to improve response time of the User Interface
- Fix: AnyDVD did not work correctly, if .bup files were missing.
This fixes problems with wrongly mastered Video DVDs.
- Change: Description in version resource of application. The old entry "watch & copy any DVD!" confused some people.
- Fix: Read error could lead to AnyDVD hang using 100% CPU load
- Fix: Deadlock when clicking into tray icon
- Fix: Hang on program exit
- Some minor fixes and improvements
- Updated ElbyCDIO
- Updated languages<!--QuoteEnd--></td></tr></table><div class='postcolor'><!--QuoteEEnd-->
<a href='http://static.slysoft.com/SetupAnyDVD3813.exe' target='_blank'>Скачать</a> (962 Кб).
